Headlamps, LCD only on inst. cluster and blinkers out
Old Oct 1, 2020 | 11:00 PM
AllUpInYoSauce's Avatar
Default Headlamps, LCD only on inst. cluster and blinkers out
Im so lost! Please help.
. Recently I was riding and all the power on my bike went out. I bought Stator and rectifier and then realized it was a 30 amp fuse under the seat. Also blew the fan fuse. When I put those in (and had already changed the rectifier) the 3 LED headlights, the blinkers and ONLY the LCDs displaying mph, clock, temp and analog tach did not work , however, the backlight , highbeam indicator, neutral light and running lights still work. I changed all fuses and checked all connections except for the 1 it prolly is, the main harness?
X! Not the main harness, however, it was before. The same ground as everybody else's. I bypassed the main harness plug with a ground wire of my own with a plug. No success. I get power all the way to the headlight plug itself. Not to blinker ends tho.
Last edited by AllUpInYoSauce; Oct 3, 2020 at 01:28 AM. Reason: Dug a little further into my problems
Cry For The Devil
Oct 4, 2023 04:10 PM
403F4
Apr 5, 2012 07:40 PM
stinkpalm
May 4, 2010 01:28 PM
lleron
May 20, 2009 09:45 PM
crookedeyemotocross
May 23, 2006 12:53 AM
