cluster
Old Apr 3, 2012 | 03:00 PM
403F4's Avatar
Default cluster
alright so i finally got my bike up and running and running well. only problem now is the cluster seems to be dead and i have no idea y??
i did do some minor electrical mods (hid headlight, integrated taillight and heated grips) but i have taken everything out and tried the cluster and i still have nothing. all warning lights work (signals oil light that sort of thing) but no speedo no tach or temp gauge i checked all the connectors up front to see if there maybe a broken wire or a pin out and could not find anything wrong. i have the oem service manual and the wiring diagrams are terrible and hard to follow. im thinking maybe a relay or something and yes i did check the fuses under the seat none blown
any and all help is appreciated thanks cbr gods
Old Apr 3, 2012 | 03:10 PM
tWoBRosHO's Avatar
i had this happen and i kept blowing a fuse that runs the blinkers and gauges but i still had a head light. Then i realized when i took off my blinker sin the rear i just ired the wire together and it ran into my integrated tail. The old blinkers i wired together were sending a current back up to the line and blowing at the fuse.
idk if this helps just what happened to me. good luck
Old Apr 3, 2012 | 03:52 PM
403F4's Avatar
what wires in the rear are you talking about? when i put the integrated tail in i just taped up the ground cuz it was not needed do i need to ground that somewhere.
i do still habe headlights and all my "dummie" lights work odo says 0km and tach speedo and temp seosor is a no go
Old Apr 5, 2012 | 07:23 PM
403F4's Avatar
anyone else able to help out with this? just removed the rear fairing and removed the harness from the tail section and am checking every pin and all relays nothing so far
Old Apr 5, 2012 | 07:31 PM
Hustlin Hussy F4I's Avatar
Same thing happened to me about 3 weeks ago. I found out it was my tag light that was blowing the fuse. If you have a split seat remove the passenger seat and find the white connector the works the tag light and remove it. If worked for me until I was able to get a new rear tail light (which i had already planned on ordering). Hope this helps.
Old Apr 5, 2012 | 07:35 PM
403F4's Avatar
i dont have a tag light my integrated tail has one on the bottom so i took the light and housing itself off the bike and unplugged the harness can this be causing a problem? and also i dont have any blown fuses the tach needle is wrapped to the right side of the needle and speedo and temp gauges dont move also odo says 0km
Old Apr 5, 2012 | 07:40 PM
LetoCharles's Avatar
403F4 - the tailight does need to be grounded, some LED lights will function without a ground, but with out the ground it can back feed and cause multiple electrical issues, connect the ground and see what happens
The_best
Dec 22, 2012 02:30 AM
Hanberg[DK]
Nov 1, 2007 11:23 AM
Det99cbrf4
Sep 16, 2007 12:36 AM
