Cluster
Old Nov 1, 2007 | 09:15 AM
Hanberg[DK]'s Avatar
Default Cluster
Im looking for a cluster which shows kilometers instead of miles. Found 1 on ebay but it was ended earlie so I didnt get a chance to bid.
All the others are miles - any chance of changing this?
Their 400USD in Denmark used, thats crazy!
Old Nov 1, 2007 | 10:27 AM
mycvil's Avatar
Default RE: Cluster
F4i? - You can switch from KM to Miles by pressing and holding the select (top) button while the key is turned on. - Only thing it doesn't change is the coolant temp from C to F.
Give it a shot before spending $400 ona gauge set.
Old Nov 1, 2007 | 10:48 AM
Default RE: Cluster
Yeah for the F4i or FSport as its called in Denmark.
Guess I could live with the temp-thingy - it also changes the odo from miles to kilometers?
Old Nov 1, 2007 | 11:00 AM
mycvil's Avatar
Default RE: Cluster
Yes - It does the speed and odometer. - Should work for you if you have the standard F4i gauge set (Digital Speed, Time, Analog Tach on the right - 2 buttons on the left).
Old Nov 1, 2007 | 11:23 AM
Default RE: Cluster
Actually im fitting it to my '98 FireBlade. Guess Ill try to pick up a cheap one on ebay.
The_best
Dec 22, 2012 02:30 AM
403F4
Apr 5, 2012 07:40 PM
Det99cbrf4
Sep 16, 2007 12:36 AM
