Cluster Cluster
Old Dec 20, 2012 | 09:27 PM
The_best's Avatar
Default Cluster Cluster
When i was riding my cluster just stopped working. No guages working,, lights,, nothing. The bike will start. But when i switch the key to on nothing lights up. Help?? Fuses good. Main fuse good. Power to cluster. But nothing.
Old Dec 20, 2012 | 09:40 PM
sjona2011's Avatar
make sure both plugs on the back of the gauges are seated well, also look at all the screws in the back of it, i replaced most of them on mine because the old ones were all rusty preventing a good connection and caused my tach to be weird, but in your case since nothing is working or coming on, check all grounds going to the gauges. all the grounds are daisy chained to each other so if the main ground is bad then nothings going to work.
Old Dec 20, 2012 | 09:45 PM
The_best's Avatar
Daisy chained?? I pulled both connectors, cleaned them and snugged them both back in.Do you know which colers they are?? I pulled all my fairings off for this lol. Im ready to ride.
Old Dec 21, 2012 | 02:39 PM
sjona2011's Avatar
daisy chained meaning all the grounds are connected to each other. but the ground wires should all be green.
Old Dec 22, 2012 | 02:30 AM
The_best's Avatar
Ok I'll check tomorrow. Most of my screws on the circuit are rusted. I'll change them all out with new
403F4
Apr 5, 2012 07:40 PM
Hanberg[DK]
Nov 1, 2007 11:23 AM
Det99cbrf4
Sep 16, 2007 12:36 AM
