Steering Stem Bearing Size
Old Jan 10, 2010 | 05:05 AM
johnnycrash's Avatar
Post Steering Stem Bearing Size
Just in case anyone wanted to swap their ball bearing steering head bearings for some tapered roller bearings i do not have the part numbers.
But I do however have the dimensions of the OEM bearings so you can
call your local shop and see what they have.
The upper bearing measures:
d= 26mm
D= 47mm
Height= 15mm
The Lower bearing measures:
d= 30mm
D= 55mm
Height= 17mm
d = inside diameter
D = Outside Diameter
height of the bearing across outside faces
Hope this helps, if i track down part numbers from NSK of SKF i will post them here!!
Cheers
Lower Bearing SKF Part # 32006 Single Row Tapered Roller
NSK Part# 32006x Single Row Tapered Roller
Upper: Bearing # is 32005 should be able to source it based on that.
Attached Thumbnails Steering Stem Bearing Size-img_0022.jpg   Steering Stem Bearing Size-img_0023.jpg
Old Jan 10, 2010 | 06:01 AM
Also Found this site, which has both bearings for $40 with dust shields.
I ordered a set...
http://www.z1enterprises.com/product...-30x55x17.aspx
Old Oct 5, 2020 | 09:40 AM
Vlogger AJ's Avatar
Default Steering head bearing size confirmation
d= 26mm
D= 47mm
Height= 15mm
d= 30mm
D= 55mm
Height= 17mm
d = inside diameter
Cheers
Can you please confirm the size of upper bearing?
Cz for 32005 the size is 47*25*15 and you have mentioned upper bearing size as 47*26*15
bullroarer
Dec 30, 2017 08:40 AM
Gega
Jun 16, 2010 08:23 AM
stunter411
Jan 5, 2009 12:34 PM
nrecore0223
Jul 2, 2008 10:53 AM
Shadow
May 30, 2008 09:27 AM
