Headlamps, LCD only on inst. cluster and blinkers out
Im so lost! Please help.
. Recently I was riding and all the power on my bike went out. I bought Stator and rectifier and then realized it was a 30 amp fuse under the seat. Also blew the fan fuse. When I put those in (and had already changed the rectifier) the 3 LED headlights, the blinkers and ONLY the LCDs displaying mph, clock, temp and analog tach did not work , however, the backlight , highbeam indicator, neutral light and running lights still work. I changed all fuses and checked all connections except for the 1 it prolly is, the main harness?
X! Not the main harness, however, it was before. The same ground as everybody else's. I bypassed the main harness plug with a ground wire of my own with a plug. No success. I get power all the way to the headlight plug itself. Not to blinker ends tho.
Last edited by AllUpInYoSauce; 10-03-2020 at 01:28 AM. Reason: Dug a little further into my problems
