Front Brake Switch
Old Sep 1, 2010 | 10:55 PM
Bumble's Avatar
Default Front Brake Switch
Hi, I did a search for front brake switch, but I didn't find what I was looking for.
My problem is that the brake lights will stay on unless I mess around with the brake lever. I have the service manual in electronic version, and it doesn't mention much about the front switch besides it is not adjustable. My question is, should I replace the switch, or is there an adjustment that might make a difference on the handle?
And I do know for a fact it is not the rear switch, that one works fine.
Thanks
Old Sep 3, 2010 | 08:06 AM
txsmainevent's Avatar
Check the mounting bolt, if you push the lever away from you does the lights go low? sounds like your lever might be sticking. I had that issue when i replaced mine with aftermarket chrome ones. I just took it back off and sanded the area where the bolt runs through to free it up.....
Old Sep 3, 2010 | 02:41 PM
Bumble's Avatar
If I push the lever away, sometimes it will make the lights go low. Actually, with the bike off I can hear a tiny click from when the switch is tripped or goes open again. Pulling the lever forward works about 50% of the time. From what I can tell, the lever is not sticking or hard to move. Maybe there is a spring in the switch that is getting weak?
Thanks for your help so far.
Old Sep 4, 2010 | 06:48 PM
The button should be where the spring is. Far as i know there is no spring on the lever it self.
Old Sep 7, 2010 | 02:06 PM
Bumble's Avatar
I will take a look at the switch and lever and report back when I fix it. Thanks.
Old Sep 30, 2010 | 11:33 AM
Bumble's Avatar
I finally fixed it. I bought a new switch, but I am pretty sure after installing the new one that the old one was fine. When I loosened the screw holding the switch, I heard it click. It seemed to be adjustable, I could move the end opposite of the screw towards the front of the bike and the lights would go off. Anyway, I installed the new switch and kept the old one since it is still a good part.
nrmskate
F4i - Wanted
Mar 13, 2012 10:40 PM
Gilly
May 21, 2011 10:01 PM
intiractive
Sep 15, 2009 09:29 AM
mpbigham
Oct 20, 2006 02:11 PM
