Front Brake Switch
Hi, I did a search for front brake switch, but I didn't find what I was looking for.
My problem is that the brake lights will stay on unless I mess around with the brake lever. I have the service manual in electronic version, and it doesn't mention much about the front switch besides it is not adjustable. My question is, should I replace the switch, or is there an adjustment that might make a difference on the handle?
And I do know for a fact it is not the rear switch, that one works fine.
Thanks
Thanks
If I push the lever away, sometimes it will make the lights go low. Actually, with the bike off I can hear a tiny click from when the switch is tripped or goes open again. Pulling the lever forward works about 50% of the time. From what I can tell, the lever is not sticking or hard to move. Maybe there is a spring in the switch that is getting weak?
Thanks for your help so far.
I finally fixed it. I bought a new switch, but I am pretty sure after installing the new one that the old one was fine. When I loosened the screw holding the switch, I heard it click. It seemed to be adjustable, I could move the end opposite of the screw towards the front of the bike and the lights would go off. Anyway, I installed the new switch and kept the old one since it is still a good part.
