Fireblade 929 no spark
Hi
i am new to the forum my name is Baz I am having problems after fitting a new frame to my 929 everything worked before I fitted new frame but now it’s not sparking. The coils are getting 12v on the black white wire and when cranking the other one pulses a earth but not spark. Also any one know what the f1 error codes are . Any idea would be appreciated cheers Baz. |
Hi Baz welcome to the forum,
Have a look here StephyGee.com But remember this manual is for USA bikes ,just the same as ours but they dont have Hiss, take a look at the fault codes and come back with your questions.:) |
No spark
Thanks for that I will take a look
Originally Posted by CaBaRet
(Post 1320990)
hi
has anyone got any information on a cbr 929 I am looking to fit a USA ECU to my UK bike . does it require any wiring mods? cheers |
You will need a USA ignition switch with the diode,. You may run into harness differences also.
thanks for the reply.
Kal has a few video's, this might help
thank you
another weird thing is it normal for the clock display to light up when I press the brake light [ with the ignition on ]
cheers |
Does that happen with both brake lever and foot pedal
