Fireblade 929 no spark
Old Apr 18, 2019 | 04:19 AM
Baz123bikes's Avatar
Default Fireblade 929 no spark
Hi
i am new to the forum my name is Baz I am having problems after fitting a new frame to my 929 everything worked before I fitted new frame but now it’s not sparking. The coils are getting 12v on the black white wire and when cranking the other one pulses a earth but not spark. Also any one know what the f1 error codes are . Any idea would be appreciated
cheers Baz.
Old Apr 18, 2019 | 04:36 AM
CaBaRet's Avatar
Hi Baz welcome to the forum,
Have a look here
StephyGee.com
But remember this manual is for USA bikes ,just the same as ours but they dont have Hiss, take a look at the fault codes and come back with your questions.
Old Apr 18, 2019 | 11:40 AM
Default No spark
Thanks for that I will take a look
Have a look here
StephyGee.com
Old May 4, 2019 | 10:44 AM
hi
has anyone got any information on a cbr 929 I am looking to fit a USA ECU to my UK bike . does it require any wiring mods?
cheers
Old May 4, 2019 | 11:01 AM
74demon's Avatar
You will need a USA ignition switch with the diode,. You may run into harness differences also.
Old May 4, 2019 | 11:41 AM
thanks for the reply.
Old May 5, 2019 | 04:47 AM
CaBaRet's Avatar
Kal has a few video's, this might help
Old May 6, 2019 | 04:57 AM
thank you
Old May 6, 2019 | 05:02 AM
another weird thing is it normal for the clock display to light up when I press the brake light [ with the ignition on ]
cheers
Old May 6, 2019 | 05:07 AM
CaBaRet's Avatar
Does that happen with both brake lever and foot pedal
