Engine 929?
Old Oct 14, 2010 | 11:21 AM
Dacarius's Avatar
Default Engine 929?
Hirde my bike on a chill evening and the rear tire slipped out on me the bike slammed down n left side smashed clutch cover and and cracked lower casing.... UGHHHH I LOVE this BIKE!!!!!!!! so i been told get a new engine.. SO HERE I AM.......... ANY ONE HAVE AN ENGINE 929 erionvracing 01.. wat about a 954 engine??? any way ANY SUGGESTIONSV WOULD HELP!!!!!!! PLEASE HELP!!!!!!!!
Old Oct 14, 2010 | 03:26 PM
vwmaniacvr6's Avatar
Do you have any pictures of the crack? I would just have the crack tig welded shut to stop leaks. That part of the lower case isn't a key part of the structure. Drain the oil and heat the area of the crack with mapp gas prior to welding it. A good welder will know to do that so most of the contaminants boil out of the pours of the aluminum. I had the eyelets that the frame bolts to on the upper case, and the mount for the swingarm bracket welded back together on my bike. It's been 3 years and over 15,000miles with no cracking or problems from tig welding cast aluminum.
Old Oct 17, 2010 | 04:08 PM
Dacarius's Avatar
Default new engine?????? PLEASE HELP
ok man well crack is ok but here is my CRACK!!!!! check these pics OUT!!!
PLEASE ANY SUGGESTIONS BESIDES A NEW ENGINE!!!!! PLEASE!!!! i have most of the piece that broke off..... i was told j.b. weld...... but if there is a way to make it stronger or more sound to hold... i will take any suggestions!!!!
Attached Thumbnails Engine 929?-dscf0117.jpg   Engine 929?-dscf0118.jpg   Engine 929?-dscf0121.jpg   Engine 929?-dscf0119.jpg   Engine 929?-dscf0122.jpg
Old Oct 18, 2010 | 08:29 PM
Looking at the third and fifth picture, if you have the piece from the case have that welded/glued in and buy a replacement stator cover on ebay. You could also remove the engine and have a shop weld in a piece, then mill it flat with the existing gasket surface. Both are much cheaper than buying an entire motor. Also please turn off your caps-lock, it's synonymous with yelling.
Old Oct 19, 2010 | 08:21 AM
Sandor's Avatar
I agree. A reputable machine shop should be able to fix that spot in the lower case. It would help if you have the piece that broke off. I had a bike that had the exact same repair and it was fine.
lanceam24
F2 Tech
Feb 21, 2011 11:45 AM
knifemaker87
F2 Tech
Sep 17, 2010 09:21 AM
julius1
CBR Zone
Jan 4, 2010 11:32 PM
98formulaLS1
Aug 24, 2009 10:04 AM
Workwell
Jan 14, 2009 10:02 PM
