Electrical issue question..
Old Jul 6, 2014 | 11:05 AM
Chefohboy's Avatar
Default Electrical issue question..
so i messed up and left my bike on without it running the other night and it killed the battery.. instead of push starting or just recharging the battery i jumped it with my truck and now im having issues
the battery dies out if im riding with my high beams
it starts up if i jump it or charge the battery.
im thinking i just get a new rectifier... im hoping i dont need a new stator.
any opinions?
Old Jul 6, 2014 | 01:48 PM
74demon's Avatar
Stators are easy enough to check. Put an ohm meter on it and see if the windings are any good.
My last charging issue turned out to be only the stator....
Old Jul 14, 2014 | 03:17 AM
bucklti's Avatar
Registered Users
Probably boiled off the electrolyte in the battery using that car battery to jump it. Buy a new battery.
Old Jul 31, 2014 | 10:47 PM
BitRex's Avatar
mine did same thing.. turns out that my rectifier was bad and it drained my batter. so i suggest get a rectifier first before buying a new battery..
Old Aug 1, 2014 | 02:25 PM
mika_u's Avatar
Sept 2014 ROTM
It doesn't drain the battery. It just doesn't charge if rectifier or stator isn't working properly.
Old Oct 8, 2014 | 03:40 PM
Chefohboy's Avatar
situation resolved. found a short in the ground wire in the connector to the front sub wire harness. so i added a thicker gauge ground right to the battery so the load doesn't melt it again. replaced the throttle body since the TPS sensor was bad. and then finally reset the ECU after i put it all back together. FYI when installing HIDs upgrade the relay behind the gauge.
That Guy in Maine
Dec 18, 2011 01:37 AM
fordfenatic09
May 14, 2011 10:05 PM
leonf4i
Nov 28, 2008 11:57 PM
3dgar RR
Nov 5, 2008 05:20 PM
sig239
Aug 3, 2008 11:12 PM
