dumb quesion
Old Sep 27, 2006 | 05:57 PM
mycool's Avatar
Default dumb quesion
can you weld the bottom of a case on the block side with a mig welder? someone in my area said they have used a spool gun to weld pieces on cases... i wasn't sure... help welding guru's
Old Sep 27, 2006 | 06:22 PM
sixs929's Avatar
Default RE: dumb quesion
Wouldn't surprise me if it could be done. I've seen guys who could damn near weld a coke can together. If you can find a real pro, he will be able to tell you for sure, though.
What happened to the case?
Old Sep 27, 2006 | 06:32 PM
sixs929's Avatar
Just saw your other post - is this the same damage from that post?
If so, Y2K had the best suggestion - TIG's the best way to go.
Old Sep 27, 2006 | 06:55 PM
mycool's Avatar
my prob. is that i know the tig is the best way to go but buddys tig went out on him back in feb. and they are not cheap!!! so wondered if i could accomplish the same thing with a mig. i was on the last post that someone mentioned it and i just wanted to get more feedback. i am hoping so! is the case cast? as you can tell i am not a welder lol
Old Sep 28, 2006 | 12:06 AM
Reckles33's Avatar
It has been a long time sence I have ran a spool gun but, Tech may be different, but ten years ago I would never have used a spool gun on the case of my bike for many reson's, 1st the weld look's like s**t 2nd. the older spool's have a very porus weld. if the Argon psi is to low you will end up with pitting all over. If it was my bike and I couldn't aford a new case I would fork out the money to find a welder with a good Tig and get it done right. I welded a case on a FourTrax 250R years ago and It looked better then the hole but it got the Job done. find a Tig welder and someone who know's how to use it.Good luck!!
ljastangs21
Jul 24, 2010 03:57 PM
Dodga367
Aug 4, 2007 02:13 AM
URRslow
May 17, 2007 06:45 PM
F4ivsLs1
May 9, 2007 04:23 AM
mavsick12
May 2, 2007 11:29 PM
