Coil Removal Question
Old Aug 12, 2006 | 01:45 AM
OzzManG149's Avatar
Default Coil Removal Question
Is there a trick to removing the coil off the spark plug? It seems to be on there really good and Im not wanting to break anything on my first spark plug change?
Old Aug 12, 2006 | 05:33 AM
NixCbr's Avatar
Default RE: Coil Removal Question
I just did mine the other day, they are pretty tricky. I just used a flat head screwdriver and popped them off. Just make sure when putting them back on they are all the way on. I found that to be harder then pulling them off.
Old Aug 12, 2006 | 11:59 AM
OzzManG149's Avatar
That\nks for the info. i didnt want to brake anything trying to get them off.
Old Aug 14, 2006 | 11:19 PM
sixs929's Avatar
When I did mine I gave the rubber boots a partial twist to loosen them, and then pulled em off exactly the way NixCbr said. Just curious - did you go in from the front (behind the radiator) or the top (under the tank)?
Old Dec 15, 2007 | 05:23 PM
92EGSi's Avatar
This is good advice... I'm doing this myself today... I managed to get them out, and removed/reinstalled new plugs... but how the hell do i get these coils back in? I can push them in up to those 3 rubber grooves... but no further... I did it from the top (i.e. removing airbox) so i don't have that much leverage... I tried using the end of a wrench against the frame rail to push it in, but no go...
Should i use some electric grease on there, or something? Or maybe drop the radiator and push them in from the other side? i can't imagine how it could be this difficult... my fingers and knuckles are RAW
Thanks
acuracbrNess
Jun 27, 2011 01:56 AM
taelvin
Apr 27, 2011 09:54 AM
powersport15
Apr 21, 2009 11:05 AM
riegnman
Jul 10, 2008 11:12 AM
gerharddvs
Nov 10, 2007 06:22 PM
