Stater coil removal
RE: Stater coil removal
If the f2's are anything like the 929, then the flywheel spins around the stator. Usually, they (the stator) bolts to the inside of the stator cover. In that event, you must drain the oil first. Remember, when you torque the bolts back down, they don't take much, around 6-12 foot lbs.
