Clicking Sound
Clicking Sound
Hi Everyone, I am new to the site but not to riding. I have my 2nd Erion Racing and I have come to a problem that I have not had happen to me yet. I am looking for some help. Soa fewmths ago I tagged a guard rail (loose gravel) and cracked my stator cover. Being that I have never changed one I ordered it and replaced it myself. Well I rode it for about 2 weeks and noticed that it was leaking oil. So I had remembered from removing the old cover that there was no gasket. I just installed it not too long ago. I go to start the bike and nothing. When I press the start button all I hear is a loud click. None of the fuses blew because I checked them all. I am lost and a little frustrated. Anyone know how to help?
RE: Clicking Sound
All the lights work, the pump primes, and I installed a new gasket. Its just wierd, because all i did was remove the old cover, installed the new one and it ran fine. I noticed it was leaking oil so I removed the new cover and installed the gasket and now it won't start. I haven't jump started it yet, Because the battery had given me problems before. So I got a new one and still nothing so my next option was going to be pop the clutch. I wasn't sure if that would help at all with the clicking sound.
RE: Clicking Sound
You need to provide more info... any more info... What do you mean the oil light is on??? does it stay on??? do you hear the injectors prime??? is there any noise when you hit the starter switch.. check the starter relay??? check the fuse for starter (should maybe be one by or on the relay??) check ground?? check power to starter?? The thread says clicking????? when you put the gasket on were all the gears ok??? there is a small starter gear that pops out when I pull the stator cover off.... Sounds like maybe the starter seized and blew a fuse.....
