cbr929 front fork upgrade/change
Old Feb 6, 2011 | 07:22 PM
sas1810's Avatar
Smile cbr929 front fork upgrade/change
hi guys!
not sure if you can answer or not, i am getting a 2000 929 with heavy front end damage. IE needs from rad forward. so i am deciding to do a project / comversion to a street fighter. (ok, let the hate start lol). so i am wondering, can i fit later model forks and trees to the existing frame, or into the old trees? any help would be greatful.
Old Feb 6, 2011 | 08:46 PM
backdoc's Avatar
Originally Posted by sas1810
hi guys!
Forks and triple trees from a 954 are a direct fit. Some of the 1k forks will fit the 929 triple tree but they are a little shorter which can affect the handling of the bike.
Old Feb 6, 2011 | 09:02 PM
sas1810's Avatar
thanks BACKDOC! i read that the 1k would fit but depending on early or late you needed a 5 or 10mm spacer for the calipers. but then again, thats not important as i need the complete front end.
this is going to mainly used for city use, so if the steering is a bit quicker beling lower, might be an advantage.
Old Feb 6, 2011 | 09:38 PM
backdoc's Avatar
Only reason I would switch to 1k forks would be the addition of radial brake calipers for the custom look. Not that you would see a big difference in braking power.
Old Feb 6, 2011 | 10:21 PM
sas1810's Avatar
thats what i was thinking. good thing is, theres nothing there, so i can have an open option now.
richbransby
Feb 19, 2013 08:52 PM
coalminer frank
May 8, 2012 02:28 PM
mark1200
Dec 14, 2010 04:54 PM
driyac
Jul 11, 2010 02:40 AM
dwhite645
Mar 24, 2008 01:15 PM
