CBR 929 wire keeps melting then blows fuse
Old Sep 24, 2022 | 03:54 PM
Jawb929rr's Avatar
Default CBR 929 wire keeps melting then blows fuse
I have a 2000 CBR 929 my fuse that is beside the fuse box under seat keep blowing and I have a melted wire going from computer to the relay that is attached under the seat it's a black and white wire any help would be great I've been trying to figure it out and cant
Old Sep 25, 2022 | 07:08 AM
dannoxyz's Avatar
hi and welcome!
Do you have multimeter and know how to use it to measure voltage and resistance?
This is 5-minute fix with multimeter; or less
What non-stock mods does this bike have?
Old Sep 30, 2022 | 09:10 PM
Jawb929rr's Avatar
Yes I do have one and there isn't really mods it's basically stock I was driving one day home and my battery got really hot and swelled up then it died tried to jump it to get it home but it died instantly after I took cables off I had to trailer it home when I got home I had recently done at valve job and wanted to check everything so I took the valve cover back off everything was good so I put it back on got a new battery put the new battery in now fuse blows soon as I hit the kill switch on
Old Sep 30, 2022 | 10:15 PM
dannoxyz's Avatar
This is main 30a fuse that's blowing?
You've obviously got power wire that's grounded. Simple to test and find:
1. pull ALL fuses
2. measure resistance (ohms, lowest scale) between each fuse-holder leg and chassis-ground (2-readings per fuse)
3. post all readings here.
Also post photo of wire that's melted. Will most likely need to cut it out and replace.
how to splice wires
Old Oct 1, 2022 | 12:19 AM
Jawb929rr's Avatar
1. pull ALL fuses
how to splice wires
It's the 20amp fi fuse that is on the outside of the fuse box
And the bl/w wire from the engine stop relay to the ecu is the one melted
I also should mention that I have no fi display and I also can't check for error codes.
Old Oct 1, 2022 | 10:44 AM
Jawb929rr's Avatar
So I've took the main harness out completely and I am going through the whole harness.i found some other issues with ground wires causing headlight to flash with turn signals and I'm going to replace black/white wire completely I'm hoping this fixes my issue any feedback would be appreciated I'm not so much new to wiring but I'm no expert and am however new to motorcycle wiring so I could definitely use any expertise anyone has
Old Oct 1, 2022 | 10:58 AM
Jawb929rr's Avatar
Old Oct 1, 2022 | 04:11 PM
dannoxyz's Avatar
simple matter. Cut out melted section and splice in new wire
Be sure to slide on heat-shrink tubing before 2nd splice
https://m.youtube.com/watch?v=uhzXRIj5FaY
Although there needs to be more than one melted wire to blow fuse.
Old Oct 1, 2022 | 09:54 PM
Jawb929rr's Avatar
Replace wire went threw main wiring harness. Stop switch is good. Still blows fi fuse soon as I flip on the kill switch I'm stumped.
Old Oct 1, 2022 | 09:56 PM
Jawb929rr's Avatar
