Cant get past 6k rpm?
Old Jul 18, 2011 | 01:50 AM
Livinloud11's Avatar
Default Cant get past 6k rpm?
In any gear im in my bike doesn't want to go past 6k rpm. Not only are the rpm's not too smooth, but when I get near 6k it starts to shutter almost like a rev limiter type thing. Anyone else have this problem?
Old Jul 18, 2011 | 12:01 PM
Hung's Avatar
Yes..I had
And the problem was my bad ECU ..
Old Jul 18, 2011 | 02:59 PM
Im gonna see if I can borrow my friends ecu then. can you gimme a little tip as to where its at exactly? Thanks!
Old Jul 18, 2011 | 07:14 PM
Swapped ECU with a friend, that wasn't the problem. I did however notice that one of the wires on my servo motor was completely off. I put it back on there but both of the wires arent snug around the fitting part. There just kind of hanging there. Could that be it?
Old Jul 18, 2011 | 09:57 PM
txsmainevent's Avatar
Try lacing the butterfly's in the servo open. Maybe they are in the closed position and suffocating the bike....
Old Jul 18, 2011 | 10:51 PM
I dont know how to "lace" them. I have no idea what to do with the excess cable.
Old Oct 16, 2011 | 09:27 AM
hazstewart1's Avatar
i had the same problem with mine after i took the tank off and changed the plugs and mine was a pinched fuel line it would run fine till about 8k then it was like it hit the rev limiter
Old Oct 16, 2011 | 07:52 PM
1BAD14's Avatar
Here is a suggestion, I had a similar issue with mine once upon a time. What I did was purchase a can of SeaFoam and poured it into the tank and road it around for about an hour after a few minutes the motor opened up and ran like someone smaked it on the back of the ***. It kind of startled me because I wasnt expecting it to kick up like that. We really didnt get a background as to what happend or how long the motorcycle has been sitting before this became the situation.
Old Mar 20, 2012 | 08:53 AM
A320guy's Avatar
New Member
Once upon a time on a cbr900,same symptoms.My air filter was sooo clogged up!Problem solved
Old Mar 20, 2012 | 11:14 AM
crazie929's Avatar
It's probably ur servo. If it isn't working properly, th bike will starve for air. Best if u disable it.
jakef4i
Apr 25, 2022 11:52 PM
jerm186
May 14, 2012 12:18 PM
mike and ikes
Aug 4, 2009 11:04 AM
way2s1ck
Jul 18, 2009 10:40 AM
audiogalexy
Mar 10, 2009 02:24 PM
