Cam chain guide replacement question
Old Mar 2, 2012 | 05:36 PM
Rhinohuey's Avatar
Registered Users
Default Cam chain guide replacement question
I am planning on replacing my CCT lifter on my 929 (35k miles) but accidentally ordered the chain guide that the tensioner pushes against instead.
My question is, am I able to replace the guide without removing the clutch assembly? And do the guides generally need to be replaced at this many miles?
I don't have time to pull the clutch cover before returning it. But if I do send it back I'll have to pay shipping, restocking, etc. so I'm just trying to determine if its easy to replace.
Thanks!
Old Mar 6, 2012 | 09:41 PM
luckboxx74's Avatar
Cam guides are not in the clutch cover. The CCT is just below the valve cover on the far right side of the motor.
Old Mar 19, 2012 | 06:55 PM
A320guy's Avatar
New Member
I too am replacing the tension adjuster,but discovered that THE ENGINE MUST BE DISMOUNTED AND LOWERED to gain access to one of the mount bolts!!!I did not see this surprise mentioned in other posts.Worse yet,the aftermarket APE manual adjuster seems out of the question,since it would be a PITA to adjust on the fly.And one word of caution:REPLACE YOUR SPARK PLUGS while you have easy access to them,or you will cry later!!!
JetPilotMike
Apr 28, 2011 04:37 PM
zone01racer
Jul 31, 2010 06:54 PM
Berto
Feb 17, 2009 12:07 AM
stewje55
Apr 21, 2008 10:04 PM
SkiBr82
Jul 17, 2006 05:44 AM
