954motor into a 929bike motor swap
Old Jan 17, 2007 | 03:26 AM
gpg's Avatar
gpg
Default 954motor into a 929bike motor swap
Has anyone heredone this swap?
Any info or advice from someone with exsperiance doing this motor swapwould be great.
Thanx
Old Jan 17, 2007 | 05:25 AM
bobjoezx's Avatar
Default RE: 954motor into a 929bike motor swap
all i know is.. the 954 hardness and 929 hardness is not that same
Old Jan 17, 2007 | 06:23 AM
gpg's Avatar
gpg
ORIGINAL: bobjoezx
You mean the wire harness?
Old Jan 17, 2007 | 06:50 PM
crazy900rr's Avatar
this is the best upgrade you can do for the 929 if you're pressed for hp. things you'll need for the swap:
1. 954 motor/throttle bodies/ airbox
2. 954 main wiring harness
3. CDI
4. instrument cluster/ subharness
5. startswitch
6. headlight switch (not sure if they interchange I know the start switch is different)
If you've got another bike to ride while you gather parts it's ideal. In order to keep the cost down to a minimum every time you buy a part from a 954 sell the one from your 929. If you do everything smart and don't get in a rush final out of pocket cost shouldn't be more than $800.
I've put two complete 929's together off of e-bay (yes they are clean title) for under 6k, and I've got so many extra parts that if I had a motor, front wheel, and a start switch I'd have a running (no title) stuntbike. Once you get into a rush, you get careless with the money and dish out more than you should. I saw a mint 929 subframe w/rear pags go for $16.50+ $22 shipping two nights ago. Just take your time.
Old Jan 18, 2007 | 08:15 AM
gpg's Avatar
gpg
crazy900rr;
Thanx dude, good info and good advice.
The 929 engineis still running strong, amazingly enough (50K miles of very hard riding, one clutchandone tranmission)[:@]
...the 929 motor really has been pretty amazingly strong, I've just beat it to death.
I've got time to collect the parts needed and not have much down time. I have the 954 motor now.
The bike is deffenitly worth saving, olins fork internals, olins shock, scott damper, galfer waves all around, braded lines, TB x-metel can...
...and it's great in the twisties, the track and for stuntin.
Isn't there a way around the CDI, instrument cluster/ subharness, startswitch and headlight switch?
If anyone knows please let me know.
-thanx again
Old Feb 22, 2007 | 02:28 PM
gpg's Avatar
gpg
I now have a running "929/954rr" and it runs awesome! What a difference from a worn out 929 engine to a fresh (9,100 miles) 954 engine, the thing is flippin fast.I had to use a 954 wire harness, cpu, upper wire harness,throttle bodys, air box, radiator and hoses,gauges and the left hand control switch. I spliced the right hand control switch using a 7pinconector from an old toyota pickup wire harness. I also had to run 3 wires from the upper wire harness to where the tip over sensor mounts under the seat. Other than all that, it's a pretty clean swap.
I also put 954 swingarm on the bike that I got on eBay for $80 shipped, it works and looks nice.
A couple more things I have coming from eBay are, 05 cbr1000 forks with Ohlins springs and a Brembo 19X18 radial mount front master cylinder. This front end's gonna be freakin awesome with the radial mount calipers on my 929's 330 Galfer waves. All I need now are 10mm spacers between the binders and the forks, and a cbr-1k front fender.
I'm glad I decided to give the old 929 a new lease on life. The bikeallready had a scott damper, an Ohlins rear shock, Galfer waves all around and steel braided lines. For ah yr2000 bike, this thing's gonna ROCK!
Thanx for the help guyz.
Krabby124
Jul 3, 2013 10:26 PM
akguy31
Mar 20, 2013 12:25 AM
torq215
Feb 19, 2012 08:34 AM
f4icrazy
Jan 13, 2009 02:18 AM
AzNBoI_585SF
Jan 28, 2007 06:56 PM
