929 w/a 954 swap - issues
Old Jul 5, 2012 | 10:26 PM
kvpracing's Avatar
New Member
Default 929 w/a 954 swap - issues
I have a 01 929 with a 954 swap in it. The other day I was riding and the battery went dead well come to find out the connector from the stator to the regulator melted away.. Now my question is I did some research on hondas parts site and see that both the regulator and stator are different part numbers per bike. My bike is still using the 929 harness should I buy a 929 reg and stator? or 954 reg and stator? or doesnt matter which?
Old Jul 6, 2012 | 08:04 PM
kvpracing's Avatar
New Member
no one?
also i have a pdf of the service manual and im missing page 13-18 just skips over that one page. anyone have?
Old Jul 7, 2012 | 07:31 AM
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Hey:
Was it near anything to get it hot, Honda regs seem to have an occasional heat problem. I would go with a electosport, ricks, or electrex r/r as they seem to have better warrantees and reps than OEM Honda r/rs .The electrical system on the 954 may have a higher output, as the 954 had Larger fuel injectors and radiator, re-mapped electronic fuel injection, and a more powerful ECU, a 954 stator is needed. If the connectors are the same and a harness is not needed then I would go with all 954 stuff as the bike was an upgrade to the 929. If a new harness is on the horizon I would check out whats different and go with a 954 one if it will work with the gauge kit you have at least then you can use all 954 electrics and make it easier to get the parts for it when needed. Oh and make sure you have a good fully charged battery as that can lead to r/r probs and stator demise.
Electrosport Industries Stator Honda CBR900RR/ CBR954RR 02-03 | eBay
NEW 02-03 Honda CBR 954RR Voltage Regulator Rectifier | eBay
2003 HONDA CBR954RR CBR 954 RR CBR954 REGULATOR RECTIFIER REG REC | eBay
Rick's Regulator/Rectifier Honda CBR954RR 2002-2003 | eBay
Dub
Old Jul 7, 2012 | 08:19 AM
Conrice's Avatar
954 stator is different. but it's different because of the way it bolts to the stator cover. it's not different as it relates to power output though, so the stator doesn't matter.
you can use a 929 or a 954 R/R. hell, you could use any bike's R/R because they all do essentially the same job.
Old Jul 7, 2012 | 09:29 AM
74demon's Avatar
Since your running a 929 harness, run the 929 r/r. That way it will plug straight in. The 929 regulator is a good one with huge cooling fins.
Old Jul 15, 2012 | 08:50 PM
kvpracing's Avatar
New Member
thanks for all the help. I ended up ordering a stator online cuz it wass cheaper and waited 6 days for it and guess what? it says it fits a 954 and it looks nothing like it nor does it fit FML looks like my bike will be sitting for 3 weeks by time i get a new one
jonnyfastnutts
Apr 2, 2014 12:22 AM
hss2010
Apr 9, 2013 09:04 AM
mk4
Apr 3, 2011 12:22 AM
Bringingf2bak
F2 Tech
Apr 23, 2010 03:22 PM
i3enny
Jun 22, 2009 08:38 AM
