cdi issues
Old Apr 1, 2014 | 12:13 AM
jonnyfastnutts's Avatar
New Member
Default cdi issues
own a 87 600 that started to have fuel pump and spark issues. did all checks and all i could find was continuity thru pulse terminals ,yellow bl. to ground in unit. it will spark from tip of plug to motor but not to electrode only. also the fuel pump not acting correct. any ideas as to whats going on? thks friends
Old Apr 1, 2014 | 08:04 AM
New Member
two of the four pins on box have continuity to ground on cdi ,does that mean cdi is bad? anyone know what the output votage on stator should be?
Old Apr 1, 2014 | 08:21 AM
CorruptFile's Avatar
June 2013 ROTM
Are they new plugs? Can you elaborate on the fuel pump issues?
Old Apr 1, 2014 | 08:40 AM
New Member
yes they new plugs, started having spark problems on two cylinders ,and fuel pump does not run either. two plugs will spark from tip to motor but not to electrode tip . or it will spark from threads on plug to motor. whatever has occured effects the spark on two cylinders and fuel pump.
Old Apr 1, 2014 | 09:17 AM
New Member
thinking about replacing whole ignition system with dyna 2000 setup.
Old Apr 2, 2014 | 12:22 AM
June 2013 ROTM
Are the 2 that don't work from either the outboard or inboard cylinders? Could be a faulty coil.
mooseboy
May 21, 2011 03:11 PM
ddavis17
May 21, 2011 11:51 AM
SparkeeVR4F4i
May 13, 2011 04:06 PM
mk4
Apr 3, 2011 12:22 AM
05CBR600F4i
Feb 6, 2011 08:40 PM
