929 with no spark
Old Jan 9, 2014 | 03:31 PM
  #21
74demon's Avatar
I can't help you in choosing a resistor, not my area of expertise. If it were mine, I'd replace the switch.
If you can find the right one, maybe wire it inline and make it removable. That'd be a great security feature.
Glad to hear its all figured out! You're almost back on the road.
Old Jan 9, 2014 | 06:09 PM
  #22
jkjel15's Avatar
Yep wiring it inline and having it removable is what I had in mind. Thanks again! Greatly appreciated
Old Apr 21, 2021 | 07:10 AM
  #23
Charliej5599's Avatar
Originally Posted by 74demon
The pink wire must have 9v. There is a resistor on the bottom of the switch that reduces it. If the ECM doesn't see ONLY 9v, it won't fire the coils or injectors. It's a security feature to prevent it bike from being hotwired easily.
I don't think that it's discussed in the manual either.
I'm at a similar issue, I see fuel being injected looking down the throttle body but no fire. New charged battery, 9.23v pink wire at pig tail from ignition switch. I put a new plug in the coil and laid it on the engine to see if I had spark, I did not. I got park when I grounded the engine to batt neg. But still won't fire. Do have some intermittent spudderi g.
Old Jul 11, 2023 | 08:34 AM
  #24
caiNBosa's Avatar
Default what size/type of resistor did you use for your inline you wired in
what size/type of resistor did you use for your inline you wired in? much appreciated
Old Jul 11, 2023 | 11:06 AM
  #25
dannoxyz's Avatar
it's not resistor, but 4.7v zener diode. And ALL guides on internet has you installing it backwards and bike still won't start!
Best to get OEM Factory ignition-switch from authorised Honda dealer. Will work correctly 1st time around. No wasting endless time and money swapping parts, blowing countless fuses and going bald with head-scratching.
baseballkid
Oct 4, 2012 07:48 AM
cncquinn
May 21, 2011 04:55 PM
jaredaamy
Jan 1, 2009 10:51 PM
Bazman
Nov 23, 2008 01:13 AM
w4kr
Jun 11, 2007 04:44 PM
