A 210 Tire on a Factory Rim.
Old Oct 7, 2013 | 12:38 PM
TorreyG123's Avatar
Default A 210 Tire on a Factory Rim.
Anyone ever seen a 210 Tire on a 929 factory Rim
Old Oct 7, 2013 | 01:26 PM
Conrice's Avatar
Don't know man. I've heard a 210 will rub on the chain...
In before the inevitable "but it will ruin the handling" post.
Old Oct 7, 2013 | 01:55 PM
74demon's Avatar
Never seen it done, but not to say it hasn't been. Go to some local bike nights, you may see it there.
The 210 will mount on the stock rim, but will not be the ideal setup for that tire. The stock 190 runs pretty close to the swing arm, chain, and chain guard as it is. The extra width may cause some clearance issues.
Old Oct 7, 2013 | 02:09 PM
mika_u's Avatar
Sept 2014 ROTM
I've used 195 and 200 whit no problem but never tried a 210.
Old Oct 8, 2013 | 12:46 AM
TorreyG123's Avatar
I'm using a Custom Swingarm so I'm just wondering what's the widest Tire that can Fit on a Factory 929 rim.
Old Oct 8, 2013 | 10:44 AM
74demon's Avatar
You can force just about any tire on the rim, but the tire will be distorted. Look at the recommended rim size for the tire you want to put on from the tire manufacturer. The stock rim is 6 inches wide.
Old Oct 8, 2013 | 11:01 AM
Conrice's Avatar
If you're using the OEM cush drive/OEM wheel - it doesn't matter what swing arm you're using. The cush drive is what holds the chain - and I've heard on a 210, it will rub. I'm sure a 210 would fit on the rim - but I'm not sure it would work with the Cush drive
Old Oct 12, 2013 | 08:33 AM
letsride's Avatar
I use a 200 on my 954 with no problems.My rule of thumb is 1 size smaller or 1 size bigger.Any thing else you'll be looking at potential problems.
CBR327
Apr 19, 2012 07:34 PM
jondecker83
Feb 25, 2012 11:58 AM
Wants a CBR
Jun 23, 2010 12:23 AM
cbrmarshall
Nov 14, 2006 05:57 AM
Fox
Nov 27, 2005 06:51 PM
