What is this?...and is it factory?
Old Feb 23, 2012 | 01:28 PM
jondecker83's Avatar
Default What is this?...and is it factory?
just like it says in the title, what is this i am pointing to, and is it factory? its the box with the wiring coming out, that looks like a power box of some sort.
Attached Thumbnails What is this?...and is it factory?-2012-02-23_10-30-59_460.jpg   What is this?...and is it factory?-2012-02-23_10-32-12_486.jpg   What is this?...and is it factory?-2012-02-23_10-32-22_914.jpg   What is this?...and is it factory?-2012-02-23_10-32-50_219.jpg   What is this?...and is it factory?-2012-02-23_10-33-06_996.jpg
Old Feb 23, 2012 | 02:21 PM
74demon's Avatar
are you pointing to the ecu? it has two large connectors on it. i can vaguely see part of a part number on it that appears to be factory honda format. if you post that number, i can look it up.
Old Feb 23, 2012 | 02:42 PM
SpongeRR's Avatar
The fourth picture from the left is looking at the connectors for the ECU, so if that is what you are talking about then yes it is a factory part, your bike will not run without it!
Old Feb 23, 2012 | 02:44 PM
Michael of Burien's Avatar
At first I thought he was pointing out the black and red braided rope?
But yeah it looks like the ECU. Although my 2003 ECU lives on top of the battery not behind it.
Old Feb 23, 2012 | 02:48 PM
SpongeRR's Avatar
Have to admit, it does look like its being held up by the rope, looks very close to the shock in one pic.
Maybe worth checking the correct fitment location?
Old Feb 23, 2012 | 03:10 PM
Where is that supposed to mount??
Old Feb 23, 2012 | 03:48 PM
any got a photo of how it is mounted. The guy has it bungeed below the battery and touch (lightly) the rear spring. Previous owner=IDIOT.
Old Feb 23, 2012 | 07:46 PM
CarbonCBRF4i's Avatar
Put the battery in first, then the battery cover, then the ECU goes on top of that. I just had all that out a couple hours ago.
Old Feb 23, 2012 | 11:22 PM
Aken's Avatar
July 2008 ROTM
Something is not right (or not stock, at least). There shouldn't be something that close to the shock, and your ECU should be on top of the battery. I can also see two aftermarket black plugs in the photo of the top of the battery, not to mention an accessory wire running off the battery.
Old Feb 24, 2012 | 08:03 AM
Ok with some elbow grease and patience i got the ecu to it original position but it is just kind of siting on top of the battery. And yes there is some additional wiring. I have a tenderer, heated grips, hid kit. The previous owner had some sort of switch hooked up that has three positions that is located near the seat that does nothing. With additional cluster of unconnected wiring. (any ideas on what that could possibly be?)
