01 929 - 2 cylinders not firing / fuel dumping out exhaust
Hello experts.
I have an 01 929....its been sitting for quite some time and wouldn't start.
With the help of a friend we took the fuel pump out and cleaned everything, including the inside of the tank. It wasn't too bad, but the fuel pump wasn't working prior to the cleaning.
When we put it all back together, the fuel pump worked and the bike started immediately and it seemed to be fine.
We let it idle for a while, cracked the throttle a few times and everything seemed completely normal. So we were quite pleased.
THEN, we put all the tools away - and about an hour later went to start the bike again. Now, cylinders 1 and 4 are not getting hot. And fuel is dumping out of the exhaust.
We then dug back into the bike. We removed the plugs and coils, and swapped them with cylinders 2 and 3, and the issue remains with cylinders 1 and 4.
So we are scratching our heads.
Has anyone ran into this ?
Any suggestions here ?
Thanks !!
Thanks !!
Did you find cause of problem?
Thanks, Paul Webb.
On mine it was the fuel pressure regulator. Flooded out #1 and #4 cylinders. Pulled vacuum hose off of regulator and fuel ran out of hose. Cycled key and more fuel came out of the FPR. Plugged vacuum hose and ran hose from FPR to a bucket. Let run to make sure only problem. Runs normal now, hits on all 4. Changed FPR , oil and plugs also just to be safe.
