Voltage drop with ignition on
Old Apr 5, 2021 | 01:49 PM
keithriley's Avatar
Default Voltage drop with ignition on
Hi All,
My '98 Blade (CBR900RRW) has been running fine for the 12 months I've had it on the road, up until now. It wouldn't start the other day so did some digging. I have 12.5v at the battery until I switch the ignition on, then it drops to about 4 and slowly rises.
My initial thoughts are a rectifier/regulator issue, or a generator issue, both usual suspects. The plug (and terminals) on the rectifier isn't the best, whether this is new or its been this way for a while I don't know.
Can anybody give a heads up where to start ?
Cheers
Keith
Old Apr 5, 2021 | 06:12 PM
@keithriley Hey, welcome to the forum. For clarification, when you say you switch the ignition to ON, you're not actually starting it, only turning the key to the on position? If so, my first inclination is the battery is not holding a charge. Have it tested. Not uncommon for them to go bad after siting for a while. Not uncommon to see the terminals get corroded looking due to poor contact. Lots of current passing through them However, bad connections would not cause a power drop like that when turning on the ignition key.
Old Apr 6, 2021 | 04:22 PM
keithriley's Avatar
Thanks for the advice there. I tackled the job today expecting to find either the alternator or the rectifier gone, but after some basic testing all proved to be good. Nevertheless I split all the electrical connections around there (under the seat) inspected them and give them a quick clean. Just on the off chance, I swapped a battery from another bike and hey presto all is well, seems the original battery, that worked faultlessly all last year, has now given up the ghost, even though it was off the bike and kept nice and warm in the house over winter.
Old Apr 7, 2021 | 08:07 AM
Good to hear that you have sorted it, batteries are a real pain with little indication when they decide to pack up
Old Apr 7, 2021 | 11:49 AM
@keithriley Excellent, glad to hear you've got it taken care of. Nothing worse than a bike that dies on ya. So, where is East Midlands? I'm not sure where Midlands is so don't know where east of it would be... lol
jet_vet2003
Nov 3, 2011 06:47 AM
SamkFL
Aug 21, 2010 01:29 AM
gnuwolf
Aug 16, 2008 08:57 PM
fireman2670
Jun 2, 2007 07:11 PM
laser20psi
Apr 18, 2005 12:52 AM
