Turn Signal (Flasher) Issue
Hello all. I have a 93 900RR with a turn signal issue that matches the issue described in the thread below.
https://cbrforum.com/forum/cbr-900rr...h-98-a-124513/
One of the suggestions is to "replace the flasher....this is a common problem with the CBRs...".
My question is: Where is the flasher located?
Any help would be appreciated. Thanks!
Sounds like the relay itself is in the gauge cluster somewhere.
https://cbrforum.com/forum/cbr-900rr...l-relay-71569/
https://cbrforum.com/forum/cbr-900rr...-relay-113100/
Now if you do decide the go all led signals later on, you may need a led ready relay. Just want to give you a heads up. If you decide to keep your original blinkers, ok to get the Honda flasher relay.
Thanks for the offer Dennis. I found out that the flasher relay is still good and have traced the issue back to the switch itself. Now I need to find out if the switch can be repaired or if I need a new one.
