Turn Signal (Flasher) Issue
Old Jan 12, 2013 | 06:29 PM
Hollywood's Avatar
Default Turn Signal (Flasher) Issue
Hello all. I have a 93 900RR with a turn signal issue that matches the issue described in the thread below.
https://cbrforum.com/forum/cbr-900rr...h-98-a-124513/
One of the suggestions is to "replace the flasher....this is a common problem with the CBRs...".
My question is: Where is the flasher located?
Any help would be appreciated. Thanks!
Old Jan 12, 2013 | 07:30 PM
kilgoretrout's Avatar
Administrator - Retired
Sounds like the relay itself is in the gauge cluster somewhere.
https://cbrforum.com/forum/cbr-900rr...l-relay-71569/
https://cbrforum.com/forum/cbr-900rr...-relay-113100/
Old Jan 12, 2013 | 07:37 PM
Hollywood's Avatar
Thanks kilgoretrout. I just found it. Looks like it's about $36 at Service Honda.
Old Jan 12, 2013 | 09:47 PM
No problem, dude, hope you get it sorted out. You may want to check out mr. cycles as well.......and ebay.
Old Jan 12, 2013 | 10:05 PM
estate4life's Avatar
February 2012 ROTM
Hey bro... I have an original one, the flasher relay. Which was located underneath the nose behind the headlight. Pull from my 94' cbr900rr. I'll ship it for $15
Now if you do decide the go all led signals later on, you may need a led ready relay. Just want to give you a heads up. If you decide to keep your original blinkers, ok to get the Honda flasher relay.
Old Jan 12, 2013 | 10:12 PM
February 2012 ROTM
Here's a picture...
Old Jan 12, 2013 | 10:17 PM
February 2012 ROTM
You know what, I have no use keeping this relay...$10, I ship it
Old May 13, 2013 | 11:01 AM
Hollywood's Avatar
Thanks for the offer Dennis. I found out that the flasher relay is still good and have traced the issue back to the switch itself. Now I need to find out if the switch can be repaired or if I need a new one.
Turbulenz
Jul 11, 2012 11:03 PM
John Cu
Sep 14, 2010 12:10 PM
meatpopsicle
Jan 9, 2008 08:23 PM
grwilson6
Jul 27, 2006 11:04 PM
Y2K929RR
Jun 3, 2006 12:06 AM
