Temp Gauge Fluctuation
Old Apr 17, 2008 | 09:06 PM
meanjeans's Avatar
Default Temp Gauge Fluctuation
Hi,
I have a 93 900rr and I noticed the other day that the temp gauge was reading 3/4 and when I was in a right turn it would climb to nearly the red line. Could I be low on coolant?
Where does the temp gauge normally stay if all is well?
TIA
Old Apr 17, 2008 | 11:46 PM
SpiritRR's Avatar
Default RE: Temp Gauge Fluctuation
Hi meanie, kinda depends on your climate, but here in the U.S. at 5k feet altitude mine stays about a third of the way over--getting up to almost half in hot weather. All these other guys with their new-fangled digitry have number displays...
The first thing I'd do is check coolant level. If it's not running too low, then I would suspect a clog somewhere. I'd remove and flush (or not remove it, but it's messy) the radiator and check the hoses for gunky buildup. Don't forget there's a white plastic overflow tank under the seat, too...
Old Apr 18, 2008 | 01:51 AM
mertan's Avatar
check the temp meter, the temp sond, and the thermostat, or coolant level.
scottiekarate17
May 8, 2012 07:12 PM
lilredhonda
Jul 23, 2009 12:06 PM
Cujo98
Jun 9, 2009 07:28 PM
tylerdaly89
Jun 28, 2008 06:05 PM
