tapping noise ????????
Old Apr 7, 2009 | 05:29 PM
steve0's Avatar
Default tapping noise ????????
hi every1,
i have a 98 900 rrw had it 4 6 months now its my 1st bike and its bin great........... the other day out on a ride i noticed a small tapping at low revs in 1st 2nd 3rd it stops after about 5k rpm it has full service history and now at 18,800 any ideas and comments on this would be a great help.
cheers
steve0
Old Apr 8, 2009 | 09:11 PM
NOSTUPIDZONE's Avatar
my has had a ticking tapping noise at low rm for the last 20k miles
honda master tech told me to run her not to worry but every noise is different have you had any experienced honda guys listen to it
Old Apr 12, 2009 | 09:01 AM
steve0's Avatar
Default cheers
thanks for the reply im probably worrying about nothing but ill take your advice and get a honda pro to have a listen thanks again
Old Apr 12, 2009 | 01:12 PM
900FighterRR's Avatar
my 95 also has what sounds like a noisy valve. I try to remind myself that unlike a car there is no sound deadening on a bike so every little internal engine noise is heard. I run conventional oil but am going to do synthetic this year, I wonder if that will make a difference? EIther way though I think that our engines just have little noises that they make and I figure that if the noises are indicitive of a problem, then that problem will not take long to get much worse (i.e. spun bearing or burnt valve) especially consider how high our engines rev, a problem will get worse really fast with revs like that.
Hope I could put you at some ease but please let us know what your mechanic says. Be good.
Old Apr 12, 2009 | 07:29 PM
camaropower's Avatar
Mine has alot of noise too, but it isn't running right either lol. I'm hoping the Ape CCT and carb cleaning will help it out a little. I also hope and pray it isn't anything major like a rod bearing, rod knock, or anything else along those lines
Old Apr 13, 2009 | 05:22 PM
again I would think that if anyone had a rod knock or a spun bearing than that problem would stop the engine from running within a few minutes of hearing the noise. If you have a rod knock that means that your bearing has excessive play or has spun. Now think of what will happen when that bearing is subjected to 10,000 RPMS or so. Whatever is left of it will be molten metal within a minute and then you will definitely know you have a problem. My Toyota supra spun a rod bearing and it sounded like a machine gun at idle and then for fun I went and drove it down my street cause I knew it was shot and within a half mile the engine would just cut out when the clutch was in from the friction. Once something like a bearing problem happens its not a drawn out issue, it can't physically work much longer after it fails. A slight tapping noise is most likely valve noise or the result of a lightly burned valve or carbon buildup. Hope that puts everyone's fears to rest, I think we are all noticing valve noise that may or may not be associated with the clearances of our valve train. It wouldn't be a bad idea for everyone in this forum to check their valve clearance specs.
Old May 6, 2009 | 03:08 PM
steve0's Avatar
Default re
cheers 4 ur advice, im gona book her in 4 a major service just b4 summer kicks off ill let u no if its bad or if im worrying 4 nothing...........
thanks again
gobigorgohome
Aug 11, 2011 05:35 AM
kszx
Jul 18, 2011 06:21 PM
yumoncbr
Apr 17, 2011 11:11 AM
helacus
Sep 5, 2008 07:50 AM
SjT
Jul 17, 2008 05:42 PM
