Tapping noise while decelerating
Old Jul 15, 2008 | 09:54 AM
SjT's Avatar
SjT
Default Tapping noise while decelerating
I have an 05 F4i with about 3400 miles on it. Today I noticed a tapping sound while decelerating in gear...kinda like a woodpecker going at my gearbox. Any thoughts of what this could be? Or if its even an issue at all?
Old Jul 15, 2008 | 01:18 PM
ampfp's Avatar
Default RE: Tapping noise while decelerating
I'll do the honors this time...
Search CCT or CCTL on this forum
Old Jul 15, 2008 | 04:50 PM
SjT's Avatar
SjT
I have searched and read in depth on the CCTL. All the information i've seen throughout the web, not just this forum, put the CCTL issue popping up around 5-6k rpm on bikes with 8k+ miles. Generally speaking. Thus why I made this post.
Old Jul 15, 2008 | 05:58 PM
DBEAU's Avatar
i just replaced my CCTL and it still taps but this time around 4k rpm. i wouldn't rule it out.
Old Jul 15, 2008 | 07:26 PM
Twiztid CBR's Avatar
All F4i get some sort of noise from the CCTL
Old Jul 15, 2008 | 11:52 PM
ampfp's Avatar
ORIGINAL: SjT
So when exactly does your bike tap? all ranges of rpm? low rpms? could be different issues. More detail is reqd
Old Jul 16, 2008 | 02:34 AM
hkwiz's Avatar
check your chain tension.
Old Jul 16, 2008 | 12:13 PM
SjT's Avatar
SjT
While decelerating, in gear, from about 5k rpm down. When i put the clutch in the noise goes away. I also noticed this morning that when I let the clutch out in neutral there is a slight grinding noise.
Old Jul 16, 2008 | 01:45 PM
ZDUB's Avatar
I would have thought the cct to and like some1 else said all of them have a slight ticking from it but if its grinding then i dk does it only grind when its in neutral or is it doing everytime you pull the clutch
Old Jul 16, 2008 | 03:48 PM
WOT's Avatar
WOT
CCTL sounds like a buzz / baby rattle not really a grinding.
