some rear set info
some rear set info
This is a pic ofa 93 900RR with 03 R1 foor controls. They bolt right on. Also, all the R1 models from 99-06 will fit the 900RR from 93-97. The stock R1 mounts match the dimensions ofthe 1"up, 1" back Rassk rearsets I have now. So far the only mod I've had to do is swap to a gsxr shift lever to compinsate the shift linkage. The Yamaha has that goofy linkage that goes up through the frame and what not.
Brake side
shift side, Crude bracket working off old GSXR brake lever. Probably not going to be permanent.
i dunno if this will help of you 900 guys but there ya go
Brake side
djhurayt
South
02-21-2010 12:25 PM
