Rough idle
Old Aug 26, 2012 | 10:54 AM
sparky68's Avatar
Unhappy Rough idle
hey chaps
Having a bit of bother with idle
Its a 98 rrw
ive stripped the carbs and cleaned them but i cant get the idle to settle out without undoing the air/fuel jet to nearly 4 turns out.
bike has K&N and aftermarket can
thanks in advance fella's
Mark
Old Aug 27, 2012 | 12:55 PM
sparky68's Avatar
no one
Old Aug 28, 2012 | 11:26 AM
sparky68's Avatar
not even one reply ?? hmm guess im the noob ah well cheers :/
Old Aug 28, 2012 | 02:43 PM
cc rider's Avatar
I was just reading about this in my haynes manual. Ill type a few sentences and maybe that will help you in case u dont have one (manual). Im a newbie too. I dont know much mechanically. i can change plugs , clean carbs, etc. but thats about it. Hope this can help you. Maybe you overlooked/forgot something. (This is summarized). Idle speed should be checked before/after the carbs are synched & when its obviously too high/low. Before adjusting, make sure valve clearances & plug gaps are correct. Turn bars back/forth to see if idle speed changes. If it does there is a problem with the throttle cables. Engine should be at normal operating temp. Snap throttle open and shut a few times, then recheck idle speed. If a smooth steady idle cant be achieved, fuel/air mix may be incorrect. Let me know how you make out.
Old Aug 28, 2012 | 02:50 PM
sparky68's Avatar
thanks very much for reply
double / triple checked those except valve adjustment (no idea how to do this)
Ive had the carbs off again today and just cant see anything wrong fuel/air screws all at 3 turns out now
if i spray carb cleaner over the 1st carb on the left the bike idles v bad and sometimes cuts out, an air leak i think but cant find it
12stones
May 20, 2019 03:37 PM
joefos
Dec 12, 2013 08:19 AM
FEELTHEIMPULSE
Apr 24, 2012 01:00 AM
Tort93f2
Apr 13, 2012 12:18 PM
mb5n537
Jun 26, 2010 10:07 PM
