Rectifier regulator...need HELP A>S>A>P thanks
Old Jan 9, 2006 | 08:46 PM
Jspring0033's Avatar
Default Rectifier regulator...need HELP A>S>A>P thanks
Hey guys would anyone know where the rectifier /regulator is located on the 93 cbr 900rr/// any help would be great thanks!!!
Old Jan 9, 2006 | 08:56 PM
pizzle954rr's Avatar
Default RE: Rectifier regulator...need HELP A>S>A>P thanks
possibly on left side of the subframe underneath the plastic
Old Jan 9, 2006 | 09:49 PM
Custom900's Avatar
If you are sitting on the bike the rectifier will be on your right side, under the rear tail section \ fairing.
Old Jan 10, 2006 | 10:12 PM
Awesome... got it off and waiting on a new one i bought off ebay.. Thanks...
One more question, The reg/rec controls how much voltage goes to the battery, so with the old one still on its holding around 12.5 at idle.... and goes up to maybe 12.7 is that normal for a bad reg/ ref or a bad stator? Or is that the stator is good but the rec/ reg is just not letting the voltage it should through to the battery?? thanks guys
Old Jan 27, 2006 | 01:14 AM
joker's Avatar
hey man check your wiring harness connected to the reg/rec, every once in a while a bad reg/rec will melt or char the inside of the harness you may have to replace that also so you get a solid connection. i believe honda sells just that wiring harness aloneif its bad.just my thoughts.
Old Feb 6, 2006 | 03:12 PM
94cbr900's Avatar
ORIGINAL: joker
this is tru i had to resolder the wires onto mine because it fried. dont forget to check your fuses cuzz when mine went out i lost a couple
Old Feb 6, 2006 | 03:56 PM
Calkidd's Avatar
Once you get your new rec make sure you have a voltage of 13.8-14 volts. This is tested by using a VOM (Volt Ohm Meter). Place the VOM to the battery start the bike turn on the high beams on and rev the engine to 5000 rpms then read the VOM. If you are not getting the correct voltage check the continuity of the stator with a common ground if you have continuity then you have a short in the stator. You can check the Ohm value between the three wires also to make sure there is no more than .3 ohms.
A buddy of mine fried his stator because his rec malfunctioned causing the stator to over charge.
paul_schmd
May 8, 2010 11:09 PM
chrisrc
CBR1000F Wanted / Swap
Apr 19, 2010 03:03 AM
cbrsixpack
The Hurricane Saloon
18
Jan 9, 2010 02:18 PM
shrek
Feb 5, 2008 09:58 AM
jeffrimerman
Dec 22, 2006 03:53 AM
