Rectifier caught on fire! Help!
Old Aug 8, 2010 | 12:26 PM
Flipside!'s Avatar
Default Rectifier caught on fire! Help!
99 Cbr900 damaged rectifier
I installed a brand new and the rectifier started and lasted me 3 months.
I purchased another & I noticed it getting hot
checked the followind voltages:
input 12-15Vac @ idle & 75-80 VAC @ 5k rpm
output 13-14.5 VDC @ any rpm
Help!!!
Old Aug 9, 2010 | 01:12 AM
MT Wallet's Avatar
A honda tech once told me that just replacing the regulator/rectifier...and even the stator alone may not solve the problem.
You may also need to change the connecting wires/connectors too.
Old Aug 9, 2010 | 10:05 AM
Flipside!'s Avatar
I had to replace the connecting plug rectifier so I cut all the damaged wire & spliced in a new one.
Old Aug 9, 2010 | 04:13 PM
CBRianWhalen's Avatar
I concur with checking the underseat stator/wiring harness plug. Mine was burned & melted from massive resistance and corrosion. Replacing/soldering new bullet style automotive weatherproof style connectors in place of the old Honda connector solved my issue once I realized the reg/rec wasn't the only issue.
Doug_
Apr 6, 2013 07:38 AM
CJardine
Jan 1, 2013 04:05 AM
EatSomeCake
Sep 23, 2011 09:30 PM
Complex.Inc
Jul 19, 2010 10:38 AM
BoostJunkie
Sep 7, 2008 11:10 PM
