Rebuild
Old May 15, 2011 | 01:41 PM
Slow900RR's Avatar
Default Rebuild
Ok guys its been awhile sence i have loged on. i need some help im in the process of tearing down my 98 900rr. and im unable to get the motor out. it seems i need some specialty tool. and to get the front tire off it seems i need one too. if anyone can point me in the right direction it would be greatly apreciated.
Old May 17, 2011 | 05:43 PM
grubeda7's Avatar
For the front tire you dont need a specialty tool. Just a 22mm (I think) socket and a thin phillips screwdriver. Stick the screwdriver threw the two holes on the right side of the axle, then hold that while you loosen the nut/bolt on the left side. Then take the brake calipers off their mount. Use a rubber hammer with socket extension to push the axle through. Wheel should come off.
Engine.... not sure lol good luck. I just took mine apart so I can help in other areas as well.
Old May 24, 2011 | 01:52 PM
pup9rr's Avatar
i got the tool you need to take the engine out off of ebay. check it
http://cgi.ebay.com/ebaymotors/Honda...Q5fAccessories
bjjrev
Sep 10, 2011 08:49 PM
rlfknlorangers
Jul 5, 2008 08:22 PM
BlindinOrange
Jul 2, 2007 05:28 PM
maxxheadroom
Sep 12, 2006 05:13 PM
mrc03rr
Jun 30, 2005 05:38 PM
