starting in neutral only.....
Old May 17, 2011 | 10:06 AM
Cognac's Avatar
Default starting in neutral only.....
just a curious question, I have a 94 900rr, can only start the bike in neutral with kickstand down and clutch engaged....wanted to know if thats how these CBRs operate...cuz my old FZR I could start the bike in any gear as long as the clutch was engaged with or without kickstand
Old May 17, 2011 | 02:51 PM
txsmainevent's Avatar
You'll never be able to start it in gear with the bikes kick stand down. NEVER! But if it is up and in gear and nothing then check your plugs at the clutch cable.
Old May 17, 2011 | 03:22 PM
exz5string's Avatar
Disconnect the kickstand killswitch & splice the wires together, worked for me
Old May 17, 2011 | 04:27 PM
Cognac's Avatar
what plugs? is there a certain thing/contact that engages when I squeeze clutch to start engine no matter what gear?
Old May 17, 2011 | 05:38 PM
grubeda7's Avatar
No, there is no "clutch engaged" switch. That lever position has no bearing on whether the engine will turn over. You've got a bad kickstand position switch or something in that line of "electrics"
Old May 18, 2011 | 12:45 AM
Yellow900's Avatar
id take this advice sounds like this one doesnt listen to lil wayne
Old May 18, 2011 | 03:49 AM
vfrman's Avatar
Party Animal, ROTM June 2014
Great idea...
Old May 18, 2011 | 04:22 AM
MadHattr059's Avatar
Annoying at first, cause I wasn't used to it. But, once you get used to it no big deal. Gotta say, don't miss not being able to do, the left hand turn pogo. lol
Ern
Old May 25, 2011 | 03:46 PM
900rr_Rookie's Avatar
Dont cut those wires at the controls..you'll never find those butt-connectors to replace the ones you cut. Look at your gauge cluster. See the light that says kickstand? It's a safety feature that prevents you from riding with the stand down. A guy I know had his stand fall down due to a weak spring and it hurt him bad
Old May 25, 2011 | 10:21 PM
SGTSKiP's Avatar
Safety 1st. They made it that way on purpose. If your in gear and accidently hit the start button, therre goes your buke to the ground if your not sitting on it.
ZeroGomer
Oct 26, 2024 09:34 PM
pricey797
Oct 13, 2013 08:55 AM
CBR Time
Jun 22, 2008 11:28 PM
F4i2005
Aug 26, 2006 08:12 PM
psycojester
Apr 17, 2006 11:43 AM
