motor swap??????
Old Feb 13, 2008 | 03:27 PM
jounin_cbr's Avatar
Default motor swap??????
Hey guys one question for ya. What motor fits in a 93 900rr with little modification like a 929rr or 954rr or maybe a 1000rr? need help and fast.
Old Feb 13, 2008 | 04:57 PM
Jeff1980's Avatar
Default RE: motor swap??????
None of those will fit in easily but anything can be done. I saw a post on here a while back of someone putting a 1000rr engine in a 900 but it looked to be far from bolt in. Whomever was doing it was deffinatly a competent fabricator. It looked really good. Search for that post and it will give you some idea of what you'll be getting into.
929s and 954s use the motor as part of the frame. Their frames do not have a lower section like the 900 so this might make using one of those a little more involved but I can't say for sure as I've never attempted it or seen a bike it has been done to. Another problem you'll run into is modifying a 900rr tank to accept a 929/954 or 1000rr fuel pump. Not a huge deal though... just cut out the bottom of the 929/54 tank and weld it into the 900 tank.
If you do find any good info on one of these swaps with pics of the job and or finished product please post here. I'd like to see how someone would do that.
Old Feb 13, 2008 | 08:32 PM
dinez74's Avatar
Its like a bypass surgery; instead ofdoing it fromyour own veins from your leg, you took it from someone else's. complications..
Old Mar 23, 2008 | 11:36 AM
Uncle's Avatar
I have been goiung through the older posts looking for some info.
I have a 95 900 and threw a rod, I have my eyes on a complete 97 motor.
Whats involved in swaping this 97 motor into my 95 bike?
Brian
Old Mar 24, 2008 | 03:57 PM
winks900rr's Avatar
I HAVE A 95 900 WITH A 99 919 IN IT NEED TO USE 99 CLUTCH CABLE THAT IS THE ONLY THING I FOUND DIFFERENT BUT I DID NOT CHANGE THE MOTOR I BOUGHT THE BIKE LIKE THAT
Old Mar 24, 2008 | 05:31 PM
The Hammer's Avatar
I remember a few years ago it was all the rage to fit cbr1100xx engines to mid-nineties fireblades. It was in every bike magazine here in the uk, although i never saw it done personally. A lot of work I would think!
Krabby124
Jul 3, 2013 10:26 PM
torq215
Feb 19, 2012 08:34 AM
moreno24
Feb 20, 2009 01:22 PM
AzNBoI_585SF
Jan 28, 2007 06:56 PM
jiveturky
Aug 30, 2005 09:27 PM
