ignition coil 900rr
Old Mar 9, 2017 | 02:47 PM
IgorCbr's Avatar
Default ignition coil 900rr
anyone knows how the wires diagram going to ignition coil for honda 900rr 1996y?
Old Mar 10, 2017 | 04:43 AM
IgorCbr's Avatar
My bike sometimes work on first two cylinders sometimes on 4 cylinder then again on 3 ?
When i dismiss the spark plugs one of them or two are wed ?
What can be the problem ?
Also i have changed new spark plugs,new air filter,new oil and oil filter.
Old Mar 11, 2017 | 09:21 PM
Tony Mawad's Avatar
If you have an intermittent problem, then I don't think it is an electrical as much as a fuel thing (you say that it runs sometimes on 2, 3, or 4).
To find out which cylinder isn't firing, put a wet rag on the exhaust, and the cold exhaust header will be the one that isn't firing.
When something is intermittent, I usually think of gas or carbs.
I think gas goes bad much faster in motorcycles than in cars.
And a 96...that is 21+ years...at this point, maybe the carbs should be cleaned (look into cleaning them or if you should).
Old Mar 12, 2017 | 08:33 AM
IgorCbr's Avatar
Yeap i cleaned them again same thing maybe i need go in workshop and sync my carbs maybe that is happend cuz lot of years and the bike is old never the carbs are synced
wookster
Mar 2, 2011 05:23 PM
wookster
Mar 2, 2011 09:34 AM
Es-f2
Sep 17, 2009 06:41 PM
Guinness
Jan 31, 2006 09:35 PM
C3_954rr
Dec 11, 2005 02:33 PM
