Hesitation problem
Old May 7, 2008 | 05:27 PM
stynkmonkey's Avatar
Default RE: Hesitation problem
I also noticed that the battery conector with the 30amp fuse that goes to the starter from the reg/rec is also fragged. Anyone got a wiring harness for sale? and how do I test the reg/rec to see if it's bad?
Old May 7, 2008 | 06:36 PM
Ghusar's Avatar
Believe it or not I had the sam problem I had to rewire because a small bottle of AXE got between the Reg and overheated the wires all better now I just redid the wiring took about an hour
Old May 7, 2008 | 08:38 PM
Did you just cut out the bad wires and get new ones? How can I tell if it was just bad grounding or if the reg/req is fried.
Old May 8, 2008 | 07:35 AM
Manic's Avatar
There was just a post about that yesterday, I tossed up a link w/ a trouble shooting chart, should still be near the top.
I just say a wiring harness on evil bay yesterday, might still be there. Looked like it was going to go cheap.
Old May 8, 2008 | 07:39 AM
The only one on there I could find was for a 98.
Old May 8, 2008 | 07:50 PM
sas1810's Avatar
Stynk! just 1 word of warning. if your changing he loom be careful you get the same country spec. i have a 94 us model and it now has a UK 93 spec. had to change the light switch as well. US models dont have the option of turning the lights off when running, UK models do. i found out by mistake.
Old May 8, 2008 | 08:40 PM
I think I might try and just replace the fried wires instead. It seems to just be the yellow ones going to the reg/rec which should be simple to replace and install a new connector. (I hope)
Old May 16, 2008 | 01:58 PM
On another topic I was walking around my local autozone just looking around and found a $4 inline fuel filter that looks about the same as the $20 OEM one. I'm wondering if there's any problems with using that filter instead of the factory spec one. What's the worst that can happen?
CBRDAN327
Apr 14, 2012 07:15 PM
clintthec
Apr 6, 2012 09:33 PM
VirginiaF4i
Apr 11, 2011 08:04 PM
Kolincj
Jul 24, 2008 10:20 PM
