Hesitation problem?
Old Jun 30, 2008 | 09:08 PM
Kolincj's Avatar
Default Hesitation problem?
Hey all, just bought a 00 929rr and am having some concerns about hesitation. The problem occurs when starting in 1st gear. Between 1k and 3k rpm's the engine chugs and does not accerelate in a smooth motion. Its just like tring to start in 2nd and 3rd gear in your car and almost stalling out. The hard chuggingdramatically decreasesafter the 3k rpm markbut I can still feel that the bike is hesitating. Not sure what the problem is? Any help or ideas? Thanks!!!!
Old Jun 30, 2008 | 09:12 PM
letsride's Avatar
Default RE: Hesitation problem?
Any mods done to it?Power commander, if you have the wrong map can do this to your bike.
Old Jun 30, 2008 | 09:16 PM
Kolincj's Avatar
The only mod on the bike is a Yoshi pipe
Old Jun 30, 2008 | 09:21 PM
letsride's Avatar
There is your problem,Yoshi's are for Suzuki's JK.It could be that you need a PC to adjust the fuel and air mixture.
Old Jul 1, 2008 | 07:11 AM
sc929's Avatar
keep it simple first....plugs, air filter dirty, injectors dirty, old gas. You said you just bought it right? Work through the basic systems and see if cleans up.
Old Jul 1, 2008 | 08:09 AM
Kolincj's Avatar
Yeah justbought it andthat makes sense. Its at 12K miles so im going to do a tune up and see if that helps. Thanks
Old Jul 2, 2008 | 12:45 PM
Hung88's Avatar
I have same problem....I mod flywheel for lightening and 10k rpmbalance..
But before I mod flywheel, My harness burning...
Now I have donerebult my wirning harness to be connected well..
Will it be Flywheel problem?
http://i72.photobucket.com/albums/i1...6/IMAG0089.jpg
Old Jul 6, 2008 | 04:19 PM
Hung88's Avatar
Wow...long time to test and found out the problem..
The fuse!! Yes..the problem is the fuse, Before you go to check engine, please clean
the wireness harness and clean the fuse box, take each fuse to clean it,
My problem solve....
Old Jul 6, 2008 | 09:19 PM
jcowick's Avatar
mine also does this if i come out of the clutch with to little throttle in first gear,,ive been told its a low end flat spot caused by me having a aftermarket pipe and a chitty k&n with no power commander,,,dont know if it helps but i imagine a pcIII would smooth that flat spot out for ya with the after market yosh
Old Jul 7, 2008 | 10:45 PM
Kolincj's Avatar
I just had the 12k mile service done and replaced the spark plugs and air filter. I knew before doing all that work that it wasn't going to solve the problem and I had a feeling that the plugs were not the issue, but I had no clue how this bike was cared for previously and wanted to start on a clean sheet. After riding for a while, one thingI did notice is that only two of the pipes are hot after a short ride (5-10 miles). I assume that it is only running on two cylinders.I then did some research throughnumerous other threads with the same issue and found out that the majority of the same problems that others have are solved by replacing the fuel pressure regulator. I also am going to check other suggestions such as battery connection and power commander. If it was a power commander....? where is that located and how do I know if there is one installed? thanks
