has anyone had this problem?
Old Sep 21, 2008 | 05:54 PM
rons93rr's Avatar
Default has anyone had this problem?
i have been having some trouble when i start my bike when it's cold(the bike not the weather). i'm not sure ,but i thought that the bike would start easier w/the choke on but i havent been able to start the bike w/the choke on at all the past month or so. so i wasnt sure if anyone else has had the same problem. i can get the bike started but it takes 4 or 5 tries, i give it some throttle then try the choke then push the choke back down and crank it 3 or 4 times then it starts. i just swaped out the fuel pump w/my other bike but it does the same thing. any ideas????? i'm stumped!!! i'm not sure if this would have anything to do w/it but i have just replaced my voltage regulator and this started right after i did this. seems like everything always happens at once.
Old Sep 21, 2008 | 06:22 PM
SpiritRR's Avatar
Default RE: has anyone had this problem?
I've always pulled the choke, then hit the starter. Not the other way round. Not sure why, something to do with changing the mixture before starting helps it work better, IDK. I've assumed that was the way it was designed to work.
Old Sep 21, 2008 | 07:10 PM
MI900RR's Avatar
Kind of sounds like some fouled plugs, but really just a guess. Know what your talking about "everything happens once." No matter how reliable a bike is, if a couple things go wrong at the same time I want to drag it into the street and set it on fire.
Old Sep 21, 2008 | 08:07 PM
dinez74's Avatar
How does the bike run? When you have to give some throttle before it can start indicates of fuel starvation. Check out the plugs too.
rons93rr's Avatar
i will change the pluggs tomorrow to see what happens. jezzz! lets see i've changed the voltage regulator, fuel filter,fuel pump now the pluggs, sh*t i should just do the coil packs and wires to. can anyone think of anything else i may change to fix this thing.
Old Sep 21, 2008 | 08:10 PM
rons93rr's Avatar
ORIGINAL: dinez74
it runns pretty good but if i get on it it seems to break up at higher rpm's.
Old Sep 21, 2008 | 08:19 PM
dinez74's Avatar
Those break up could be a sign of fuel starvation too. Check out the jets. I might be wrong all way but its worth trying.
Old Sep 21, 2008 | 08:39 PM
rons93rr's Avatar
i'm trying to wate until spring i figure i will have the carbs done and i may have them check over the entire bike just to be safe. i waunt it running like new again like when i got it last august.
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
vietladin
Dec 25, 2007 09:48 AM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
