Gearbox problem?
Old Jun 17, 2009 | 04:59 PM
twjtiger's Avatar
Default Gearbox problem?
I have an issue with the gearbox on my bike and hoped someone here may have run up on this problem before. The shifting is OK, I have never been on a Honda that wasnt "clunky", but when I let off of the gas or press the clutch in to change gears, there is a knocking noise that comes from the gearbox. I am pretty much clueless about anything dealing with motorcycles and had a shop tell me that I would be better off replacing the whole engine if I was going to have to work on the gearbox. I find that hard to believe, anyone have any ideas about this?
Old Jun 17, 2009 | 05:02 PM
twjtiger's Avatar
Oh, one more thing to add, it is a 1995 900RR
Old Jun 17, 2009 | 05:14 PM
low4door's Avatar
easy first step is to check your clutch basket and berring inside
Old Jun 25, 2009 | 10:48 AM
albert jackman's Avatar
Default 1995/96/97 900rr transmission knock
I have done some very extensive research into the clunk in the transmision when you open up the throttle and back of the throttle and its normal. It accually back lash in the shift dogs.
91f22
F2 Tech
Jun 27, 2012 12:17 PM
oldwhite600
Apr 22, 2012 06:57 PM
ozengines
Aug 22, 2011 07:21 AM
Swe_man
Apr 29, 2011 04:19 PM
kreg
Nov 11, 2006 09:22 PM
