Gas vaccum line
Old Mar 18, 2009 | 02:37 PM
smokertoker's Avatar
Default Gas vaccum line
Hello all,
I have a rampad vaccum line and was wondering if someone could help me figure out where it is supposed to be connected to. Okay here goes. If you need pictures I can do my best. Okay, The vaccum line runs from my pitcock on the gas tank then splits... One of the splits connects to about the middle of the four carbs and the other end connects to.?. I cannot find anywhere that I believe this should connect. Please help! This is a '98 CBR 900.
Thank you
Old Mar 19, 2009 | 08:04 PM
axelthrasher's Avatar
I've got a 1997 CBR900RR and I am fairly sure that my line doesn't split. Take some detailed pictures and I will try to help you out as much as I can.
Old Mar 19, 2009 | 08:46 PM
Maybe I just need to remove the extra line??? I just have it plugged right now.
Thanks for the help!
Attached Thumbnails Gas vaccum line-three-way.jpg   Gas vaccum line-into-engine.jpg
Old Mar 21, 2009 | 04:23 PM
camaropower's Avatar
Does it function properly with it plugged? I know my 95 doesn't have a split in it. I actually just put a vacuum petcock on mine so I just ran one line straight into the piece in the middle of the carbs. Hopefully someine with a 98 will confirm that tho
Old Apr 8, 2009 | 04:29 AM
k4y_d1's Avatar
I have 98 CBR too, there should be 2 lines come out from the petcock. One with bigger hole is for the fuel line and that should go into the carbs. And the other smaller hose, that's for vacuum line that should connect to engine block (left side of the block if you sit on the bike)...just take a look there.
Old Apr 15, 2009 | 11:53 AM
Thanks man! I took a look, and I have the connection going into the block, it is just below where the carbs connect to the block. Which carb does the other end of the line attach to? Thanks again!
Old Apr 17, 2009 | 03:57 AM
k4y_d1's Avatar
on my bike, there's no extra line. i think you can remove it, i don't have problems with my bike by using only 2 lines from petcock. One to engine block for vacuum and one to carbs for fuel.
hbaum11
Aug 8, 2013 07:07 AM
torence20
Jun 4, 2013 10:52 PM
Browntowns20s
May 4, 2009 06:27 PM
deek98
Sep 29, 2006 07:36 PM
deek98
Sep 29, 2006 07:18 AM
