Front forks question.
Old Apr 15, 2009 | 09:56 PM
ato4life's Avatar
Default Front forks question.
i recently bought a 95 900rr. it needs new forks and a new front tire. i am looking to buy a set of front forks but there are off a 93 900rr. Will a set form a 93 900rr work on my 95 900rr? thanks for the help, i am sure that this wont be my last post.
Old Apr 16, 2009 | 05:08 PM
SpiritRR's Avatar
Yes, '93 forks will bolt right on to a '95. Try to go newer, though (up to '97), if you can find them. Most '93 forks were made as early as 1991 and 1992.
Old Apr 17, 2009 | 02:46 PM
ato4life's Avatar
thanks for the help
Old Jul 10, 2010 | 06:29 PM
cbrtegsupra's Avatar
I know this is an old thread but I have been searching around cause I wanna upgrade my front suspension for one and two the front wheel is bent as well as the right fork.I have 1993 900rr and wanna know if i can use a newer fork set up off a 900rr gsxr 1000 929 ect.I have been searching but no real definative answer on what will work. Thanks in advance.
Old Jul 11, 2010 | 01:40 AM
Hondas Rule's Avatar
929/954 front end is a direct bolt on as long as it has the ball bearing steering head, You will need the whole frontend. I.E. forks trees fender clipons rotors calipers and such, I believe some of the 954's had the same style bearing as the 900
wixxxman
Aug 22, 2013 02:25 PM
TMAX
CBR1000F Wanted / Swap
Nov 18, 2009 12:41 PM
bluej511
Sep 10, 2007 09:58 PM
abreu3r
Apr 24, 2006 05:55 PM
