Cluster/speedo LED bulb replace on older model bikes
Old Jan 2, 2013 | 10:21 PM
  #31
estate4life's Avatar
February 2012 ROTM
It cost me $35 for 9 bulbs (7 T10 & 2 T6.5)
eBay got some super cheaper too...purple too...I got blue because superbrightled don't carry purple. If cost so cheap we can buy extra set to swap colors any time...
https://touch.ebay.com/tablet/search...2%3Atrue%7D%7D
Old Jan 3, 2013 | 05:09 PM
  #32
February 2012 ROTM
Hey members, i found out for our older models....believe it is 93-99, our cluster light bulb is the easiest to install. Pull, plug & play.... I check out bluegauge website, the newer models, many bulb are weld/solder on. So if DIY, you need to remove the face plate, cut & re-solder the led.
I found some led bulbs in ebay for crazy less cost....
the larger ones is T10 (type 194) - color onces a a bit more cost.
T10 led in Light Bulbs | eBay
the smaller ones are T6.5 (Type 24 )
T6.5 led | eBay
Old Jan 3, 2013 | 05:13 PM
  #33
February 2012 ROTM
I also want to note that I am liking the led day after day...the blue background is amazing. I got blue led for the RPM & MPH background, for the neutral I got green, red for oil, blue for high beam...ditto.
Even though there is green lens on neutral, using a green bulb still works great.
The led color is so vibrant! I just love it!, if I were to get all the bulbs from eBay, this will be like a $12-$15 mod, but I got it from superbrightled...so $35. Any way if fine but you will love the color....better than OEM candle is a jar.
Old Nov 2, 2015 | 09:31 AM
  #34
mirador1987's Avatar
Hey guys, sorry to go digging up an old thread, but hopefully at least one of you is still around!
I'm needing to replace a couple of instrument cluster bulbs on my '95 F3, so considering going LED with them all.
My question is - do I need to convert the indicators & relay to LED in order to do this, or can I do *just* the dash?
Thanks!
estate4life
Jan 4, 2013 06:51 AM
musantemike
Mar 11, 2010 01:58 PM
A4wheelin
Apr 21, 2008 02:57 PM
rdsii64
Aug 15, 2007 05:24 PM
