charging problem
Old 04-27-2007 | 10:14 PM
jasonp's Avatar
Default charging problem
how do i test to see if my 99 900rr is charging or not ?if i just pull the battery wire off while it is running should it stay running or should it die?????
Old 04-27-2007 | 10:29 PM
HAVOC's Avatar
Old 04-27-2007 | 10:48 PM
jasonp's Avatar
Default RE: charging problem
thanks for the info havoc it helps a lot
Old 04-27-2007 | 11:05 PM
HAVOC's Avatar
glad to help ... chances are your regulator is going to be your problem lol
Old 04-27-2007 | 11:39 PM
Mad Hatter's Avatar
Dang! Beat me to it! Just make sure your wires aren't burnt or corroded and ALL of the connections are good. It also wouldn't hurt to throw an extra ground wire to the reg/rec from the negative side of the battery.
Old 04-30-2007 | 01:04 PM
undgnd's Avatar
You need to use a voltage meter on the battery, while the bike is running. The voltage should read between 13 to 15 volts.
Old 05-02-2007 | 02:44 PM
900RR Puzzle's Avatar
Here is a link to where you can download a "fault finding" PDF document. Save it and print it out. If you follow the flow charts on it, it will help you trouble shoot battery, reg/req, and stator problems.
http://www.electrosport.com/electros...t_finding.html
gdjohny
01-10-2014 12:09 PM
mjimenez1
02-06-2010 09:28 AM
blaster
11-19-2007 12:02 PM
octec
08-24-2005 05:03 PM
Quick Reply: charging problem
