charging problem which is most likely
Old Jun 11, 2005 | 06:55 AM
octec's Avatar
Default charging problem which is most likely
riding my bike last night..... worked great right up to the ride home. dash lights started dimming and the headlight looked like a candle
I know it ran the battery dead..... barely made it home. It stalled and I coasted the last block into my yard.
which is the more likely culprit..... the voltage regulator or the stator?
as far as I know the stator usually dies slowly..... not abruptly like tonight, or am I wrong?
anyone with some insight?
Old Jun 11, 2005 | 11:18 AM
sgwkiip's Avatar
Default RE: charging problem which is most likely
i had the same problom, i just replaced both, but everyone told me its just the regulator
Old Jun 11, 2005 | 11:23 AM
chainstretcher's Avatar
Admin Emeritus & MVN
How old was the battery? Probably the regulator but I'd test everything instead of just replacing.
Old Jun 11, 2005 | 01:32 PM
sirlimpzalot's Avatar
Regulator rectifier is more than likely the problem, easy to replace..just make sure it is bolted to the subframe before you try the new one. It needs to be grounded or you run the chance of blowing that one also
Old Jun 12, 2005 | 04:36 AM
octec's Avatar
former owner was a monkey F@cker!
rectifier is fried.... along with 4 different wires. one wire seemed to be pinched and then grounded to the frame... one ground completely burnt up
the rectifier was zip tied to the battery box (no ground) dunno how it lasted this long
I boosted the bike this morning and put a meter on the stator wires..... puts out good current.... bike battery was good enough to boost the car after it was charged
sooooo...... now I gotta rewire a bunch and order a new rectifier
nothings picks my butt worse than people who jerry rig IMPORTANT stuff
Old Jun 12, 2005 | 09:38 AM
Just damn [:@] Luckily it didn't fry anything else. I believe while it's down waiting for a new regulator I'd go over the entire bike (particularly the wiring) with a fine tooth comb.
Old Aug 24, 2005 | 05:03 PM
maxima/nismo's Avatar
oh boy, i had a similiar problem as you buddy, but the bozo that i am, couldnt be bothered going to a garage and just ordered my stator, now i'm wondering if i should get the regulator as well. doesnt pay to be lazy, i'll tell you that much.
gdjohny
Jan 10, 2014 12:09 PM
mjimenez1
Feb 6, 2010 09:28 AM
blaster
Nov 19, 2007 12:02 PM
jasonp
May 2, 2007 02:44 PM
